U4GM What is the best loadout for the Echo 12 in Black Ops 7
Hier vind u de algemene voorwaarden en de nieuwtjes omtrent het forum.
Smsnaker235
Bericht door Smsnaker235 » di 16 dec 2025, 04:47
In BO7, shotguns are already starting arguments in the lobby, and the Echo 12 is usually the one that kicks it off. If you’re trying to learn it fast (or just want a stress-free place to test stuff), a CoD BO7 Bot Lobby can make the early grind way less annoying, because this gun punishes “figure it out mid-match” more than most.
How the Echo 12 Actually Shoots
The big thing: it’s not a normal spammy shotgun. It’s got that two-shot burst feel, then it yanks you into a pump cycle. So you fire, fire, then you’re stuck for a beat. People lose fights because they keep pulling the trigger like it owes them money. You’ve gotta learn the rhythm: one-two, breathe, move, one-two again.
Stop Aiming Down Sights
A lot of players try to “be precise” and ADS, but the Echo 12 doesn’t really reward that. You’ll feel slower, you’ll lose your corner timing, and you’ll die to an SMG that never stopped sprinting. Hipfire is the whole point here. Keep your screen centered, pre-aim with your movement, and let the pellets do the work.
1) Muzzle and Laser for Hipfire Control
Start with the Binary Echo Choke. It tightens the spread so your shots land where you expect, not somewhere in the next postcode. Then add the Convergence Box Laser. Together they turn the Echo 12 into a “peek and delete” tool, especially when you’re sliding or quick-shouldering a doorway.
2) Barrel and Ammo to Avoid Hitmarkers
Next, use the 18.7" Magellan Barrel to stretch your effective range a bit, because getting hitmarkers up close feels criminal. For ammo, the Greaves Fortrex Drum helps you stay in the fight longer, and the Turnkey Rapid Drum fire mod keeps the follow-up pressure high. That matters because you’re often taking two fights back-to-back on an objective.
Playing It Right in Real Matches
This gun’s best when you’re mean with positioning. Don’t ego-challenge long lanes. Cut through side rooms, work headglitches you can jump around, and commit to close routes. If you’re about to push a stack, reload early, then go in with that one-two rhythm ready.
Where It Shines
Once it clicks, the Echo 12 feels unfair in tight hills and busy choke points, and that’s why people get hooked on it. If you want to practice the timing, test ranges, and dial in a setup without burning your patience, running a u4gm CoD BO7 Bot Lobbies can help you lock it in before you take it back into sweaty public matches.
